Old 07-11-2008, 09:46 AM   #12
Brucelee
Brucelee's Avatar
Pretty cheap for a shade tree mechanic to complete
Special Edition, Inc.
Yesterday’s Classics Made for Today
Deluxe Pre-Assembled Body Package
Starting at $18,995
F.O.B. Bremen, Indiana
What is it?
The “DELUXE PRE-ASSEMBLED BODY PACKAGE” program provides the specialty automotive
enthusiast with a quality product, in a complete and comprehensive package. This alternative affords a
savings over the “Roller” or “Turn Key” versions by allowing you, the customer, to supply a portion of the
parts and labor relating to the final assembly procedure, yet does not demand an inordinate amount of
specialized skills or professional assistance such as painting, wiring, and upholstery.
This package includes ALL of the following:
o The complete hand-laid fiberglass body, painted with Sikkens base coat/ clear coat to automotive
standards. The doors, front hood with support rod, and rear deck lid with support rod are hinged,
latched, weather stripped and fully adjusted.
o The body comes pre-mounted to a 3” tubular steel frame that is an integral part of the body/chassis
system. It includes a fully adjustable front axle beam with torsion bars installed and rear
suspension components complete to the spring plate assemblies. Tubular steel is an extremely
strong method of construction and gives the Spyder 550/550 S excellent torsional rigidity resulting
in crisp handling, consistent door gap, and superior fit and finish.
o The self-parking, 2-speed windshield wiper system is completely installed and wired.
o All of wiring is completely installed. This includes the 3-gage cluster, all switches, relays, engine
harness, lighting and a complete fuse panel. The steering column with turn signal, emergency
flasher and wiper switch is installed.
o The removable convertible top and steel scissor mechanism is completely assembled and
operational.
o All latches, hinges, and release cables are installed and fully adjusted.
o Full leather interior is completely installed including adjustable bucket seats, leather wrapped
steering wheel, shifter and emergency brake boots.
o The interior is completely carpeted. A set of Spyder 550 floor mats is also included.
o The accelerator, emergency brake, clutch, and speedometer cables are installed. The cable shift
mechanism is complete and pre-installed.
o The fuel tank, aluminum “Quick fill” gas cap, and fuel lines are installed.
o Pedals, dual circuit master cylinder, reservoir, and all brake lines are all installed.
The “DELUXE PRE-ASSEMBLED BODY PACKAGE” is extremely complete. The builder need only
supply the engine of his choosing, a transaxle, brakes, wheels, tires, lights, fluids and some hardware (most
items available in the optional packages), some basic mechanical ability and approximately 25 to 30 hours
of assembly time.
Prices are subject to change without notice. A $5,000.00 deposit must accompany all orders. Please call
for availability.
Special
Rich Belloff
