Old 07-09-2008, 01:30 PM   #20
2001saxster
Originally Posted by Boxtaboy
Man, you guys are scaring me. Sorry to hear. I thought the slipped sleeve issue was fixed after 1998 model runs. Yours is a 2001 I assume?
Yes, mine is an 01. Slipped sleeve is what they said it most likely was, but as far as I can tell, they can really only go so far in diagnosing it without totally ripping the engine apart. They did enough tests to determine it was a problem deep within the engine that could not be repaired (or at least that they wouldn't repair) that was causing coolant to mix with the oil.
2001saxster is offline   Reply With Quote
