Old 07-09-2008, 08:06 AM   #1
AddictionRacing
Originally Posted by rick3000
For the most part IMS does not occur on pre-'01 Boxster's, but it can on the rare occasion occur as it did with Addiction. But that doesn't mean you should be discouraged from getting a Boxster. Engine failures do happen, but if you have a warranty there is nothing to worry about.
Addiction, I am wondering if your car had an engine replacement after '01. You should check the service records or try and match the engine serial number. If you had an engine replacement, PCNA my be liable to fix it.
I don't mean to jack this thread, but I saw a post you made on Renntech about an X at the end of the serial number meaning it was replaced. Did you get an answer as to whether that's true or not? Once I get the serial number how can I tell when the motor is from? Thanks!
AddictionRacing is offline   Reply With Quote
