I've got my boots/mobil1 grease. I'm just waiting for the new axle nuts. I'll be keeping my fingers crossed that I don't snap a header bolt.
Originally Posted by JackG
Hi Sputter,
The axle puller is a device that mounts to the lug bolt pattern, and has a center threaded bolt that pushes the axle out of the hub. I borrowed one from Advance (I think). They are common for working on front wheel drive cars.
The drivers side on an "S" is the tighter side, and requires dropping the header. The passenger side does not require this step on an S.
Good luck with it, and make sure you get those CV joints clean and greased back up. Don't want to have to do it again anytime soon, huh?
