Old 07-02-2008, 08:53 AM   #3
CJ_Boxster
Send a message via MSN to CJ_Boxster
If you dont find the intructions using the search...
You'll need a 10mm socket with extension, Cross screw driver and a allen socket (forgot the size) with extension.
first manually lift the rear spoiler by pressing the up button on the button on your fuse cover where the driver sits. Then take out the 3 snap in button screws from your spoiler by pressing the center of them inwards then pulling the entire plastic screw out
now remove the painted peice of the spoiler, underneath you will see 2 allen bolts holding the metal frame of the spoiler to the car... remove those.
once removed you can lift the metal frame out, then you'll see several screws holding the center upper portion of the bumper to the car, remove those.
then lay on the floor and look under the car and you will see several screws holding the bottom lip of the rear bumper to the car, remove any that you see there.
now look under your bumperettes, theres a small hole slot under each one, inside the slot theres an allen bolt, loosen it and the bumperette can be pulled off.
finally, look on the inside of the rear wheel tunnel and you will see either 1 cross screw or 1 10mm bolt head, it holds the outter edges of the rear bumper to the rear fenders, one per side. remove them and you can go ahead and pull the rear bumper off now.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
