The temp guage is not an accurate reflection of engine oil, it measures coolant temps and none to accurately at that.
An engine oil can exceed the coolant temp by up to 100 degrees and you would not know that.
Having said all that, why all the hand wringing on the oil change? The moron put the wrong oil in your car. Drain and fill. Take you like 30 minutes tops.
Good luck.
