Old 06-27-2008, 03:20 AM   #3
JCL12
Not sure why a Porsche certified tech would put unapproved motor oil in my car or why the porsche manual states synthetic 5w30 is ok. Yikes! Maybe it is time to trade and get that lexus
Anyways, I'll probably just integrate this in with my 45K since I am at 42K... I scanned the work checklist & inspection plan for the 45K. It looks like a pointless gorified inspection. Anything here I can DESCOPE to cut costs and anything I need to add on? I was under the impresion there were more belts that needed changing...
15,000; 45,000; 75,000; 105,000 mile service
Required for the Emmission Control System
Maintenance every 15,000 miles
Change engine oil
Required Maintenance and Lubrication Service
Major maintenance at:
15,000; 45,000; 75,000 and 105,000 miles
Diagnosis system: Read out fault memory
Underside of vehicle and engine compartment: Visual inspection for leaks (oils and fluids) and chafine (wires, lines and hoses)
Underbody paneling: Check that the underbody paneling is securely fastened - replace any damaged and/or missing panels.
Power-assisted steering: Check fluid level
Coolant hoses: Check condition. Radiators and air inlets: Visual inspection for external debris and blockage
Coolant: check level and anitfreeze
Particle filter: Replace filter element
Brake hoses and lines: Visual inspection for signs of damage, correct routing and corrosion
Brake fluid: Check level
Drive shaft: Visual inspection of the boots for leaks and signs of damage
Tires and spare wheel: Check condition and tire pressure
Door locks, lid locks and safety hook of the front lid, Check to ensure that they are adjusted correctly and function properly
Vehicle lights: Check operation
All headlights: Check setting
Horn: Check operation
Windshield washer, headlight washer: Check fluid level and nozzle settings, make sure to check the antifreeze during winter months
All other electrical equipment as well as indicator and warning lights: Check operation
During road or dynamometer test:
Brake pedal and parking brake (also operating travel), engine, clutch, transmission, automatic speed control, steering system, heating, air-conditioning system and instruments: Operation-test
Oils, fluids: Visual inspection for leaks
Additional maintenance every 60,000 miles
Replace polyrib belt
Additional maintenance every 90,000 miles
Manual transmission: Change oil
Automatic transmission: Change ATF and ATF filter
Differentials: Change oil (includes front differential, if equipped)
JCL12 is offline   Reply With Quote
