Here's what i would do:
Have someone press firmly down on the front of the car while you put your ear next to the suspension by each wheel. Then do the same for the rear. It will be obvious which bushings need replacement.
Take your car to a different shop. (maybe lookup some reviews or ask the forum members for a referral) and have them just replace the parts that you found to be making the noise. I wouldnt mention that you already had it looked at.
Once again, if its only one lower control arm, it should only run you about $450 parts & labor included.
If the other parts truly need replacement. They will let you know.
Good luck
