Sounds to me like your transmission (top transmission) cables have failed. These are encased in a vinyl sleeve which shrinks and pulls the actual cable out of the transmission recepticle.
You can sometimes force the sleeve back so you can get the cable to engage, but sometimes, you need to replace the cable. If replacing, you'll need to manually operate the top to access them and then need to synchronize both sides so they operate in tandom.
