Old 06-15-2008, 05:24 AM   #1
2000SoCalBoxsterS
Hey LowFlyR, thanks for the link. My Bentley's manual didn't have the rotor thickness spec for the Boxster S while your link provided them.
Now I have a few questions.
For the Boxster S new rotor thickness is 28mm Front and 24mm Rear. The wear limit is 26mm Front and 22mm Rear. So you've got 2mm from new to wear limit?
Then there is a machining limit which is about 0.6mm thinner than the wear limit for the Non-S Boxster do know what it is for the S rotor?
What exactly is the "wear limit" ? It's not the point at which you need your rotor's cut is it? Every 2mm ?
Is the machining limit the point where you have to buy new rotors?
My Bentley's shows the machining limit for the Non-S Boxster rotors at 22mm Front and 18mm Rear. They don't provide this data for the S model.
http://i25.tinypic.com/20aq3wn.jpg http://i26.tinypic.com/2zguetx.jpg http://i28.tinypic.com/2jdi1ok.jpg
2000 Boxster S: 18" Turbo wheels w/color crests, Litronics, Onboard Computer, Traction control, Cruise, Painted rollbar, Leather interior, Aluminum package, headlight washers, Porsche GT3 seats, windstop, Hi Fi six speaker amp package, DSP, CDR 220, Limited Slip, side airbags, BK Rollbar extender.
2000SoCalBoxsterS is offline   Reply With Quote
