Old 06-13-2008, 04:49 AM   #1
aBsOlUt
Car vibrates when A/C is on.
Hey guys,
I recently just picked up my '04 BoxsterS from the dealer. They did some transmission work to fix the 2nd gear issue which was popping out...
They took everything out and then rebuild the car. However, when I picked it up everything was fine except when I turned on the A/C the car would vibrate (NOT SHAKE) a lot due to the required power for the A/C to work. When I turned it off everything was back to normal.
What gives? Maybe the idle RPM were not set correctly when they were rebuilding the car? Should it be easy for the dealer to fix?
I won't see my car for month because I am out of the country but still wanted to know.
Thanks in advance.
aBsOlUt is offline   Reply With Quote
