Originally Posted by edevlin
I started up the Boxster this morning and headed down the street. I noticed that it was difficult to shift gears, so I turned around to head back home. That's when I saw the trail of fluid heading back toward the house. No warning lights came on, the fluid looks like transmission fluid and the oil levels did not go down.
I just had it towed to the independent shop that I use in Richmond. They said they should be able to check it out this week to see what happened. There were no unusual noises, rpms were low, just had trouble shifting gears, never had any fluid leak onto the floor before.... Any ideas?
Ed
Well if the fluid leaked is very thick, then yup its transmission gear oil... Your leaking it from 1 of 4 possible areas.
1) Front main tranny seal
2) Drain plug
3) Passenger side axle seal
4) Driver side axle seal
Jack it up and take a look.
