Old 06-08-2008, 09:33 AM   #1
djoa
Originally Posted by boxs2000
But I'm not a racer, so any recommendation for suspension option? e.g. keep the old spring, just change the shock into Bilstein HD? or H&R + Bilstein Sport?
This will actually make your ride even stiffer. You may want to start with changing your tires as they can significantly change the ride quality. Certain tires can make you ride ride real stiff etc.
Also does you car have ROW 030 suspension? To verify look under your front hood there is a Porsche sticker and decode your option code here http://www.kindel.com/porsche/options.asp
good luck
the under hood sticker has gone, I got no idea whether is it ROW M030 =P
djoa is offline   Reply With Quote
