Old 06-05-2008, 07:18 PM   #14
RandallNeighbour
This was the first repair I had to make on my boxster. Everyone in front of me thought I was a prick driving a porsche and thought I should be the only guy on the road. Grrr.
You will definitely need to take your car and proof of ownership to a dealership to retrieve your radio code if you repair this yourself, and you should not pay anyone to repair it. It's too easy.
The horn pad plate can be purchased through Sunset Porsche in Oregon for near cost. Disconnect your battery's negative post, drink a couple of beers and kill a half hour, and then remove the horn pad.
You'll need a T15 torx screwdriver (or thereabouts in size) to remove it, and there's two screws behind the wheel. The horn pad comes right off when you remove them.
You'll see a squarish metal bracket with four black rubber seals on it that have worn out and are causing inertia-induced contact between the horn pad and the base of the wheel.
You can either replace that bracket or cut some garden hose and replace the black discs with it and put it back together... that would be the cheap fix and a lot of guys do it.
Buy a Bentley Boxster repair manual asap. You'll be referring to it a lot if you keep your boxster for any length of time.
I was never mechanically inclined but after a couple of trips to the dealer for service, I decided to learn how to do stuff on the car. Just rebuilt a caliper, swapped out a warped rotor, and bled the brake system. No big deal really. Just a learning curve and a new experience.
