Old 06-05-2008, 05:48 AM   #22
Chills
Send a message via Yahoo to Chills
Originally Posted by ddb
Chills,
The install and car in general looks great! Seeing yours, Trieullionaire's and others Avic set-ups makes me want to attempt my own install. Especially with Tri's kit available.
Did you attempt to install the Nav. antenna out of view? I've read it can be installed under the alarm module, but looks like it would be a tight fit based on your pictures. Obviously it works better exposed.
Are you running the standard OE 4-channel amplifier?
Thanks,
ddb
Thanks ddb. I thought about trying to hide the antenna, but I didn't want to mess with the great reception I get on the dash. Plus I barely notice its there.
I have the Bose upgrade in the car and I kept the stock amp and speakers. The sound is much improved over the stock Becker HU.
With Tri's kit the install will be a snap. I didn't have his kit and I was able to do the install... and I had never done one before.
I bleed green
It's not about the summit, it's about the climb.
http://i133.photobucket.com/albums/q46/chills1138/2.jpg
Chills is offline   Reply With Quote
