Old 06-04-2008, 09:12 PM   #3
Lil bastard
Lil bastard's Avatar
Yep... battery, ignition switch or alternator (which caused the battery to go bad).
Eliminate the battery and alternator by checking them with a DMM. If the battery reads 12.6 volts from terminal to terminal, cables off, and cables on, car running same test voltage should read 13.6 - 14.5 volts (alternator voltage), any other values and this is your problem.
If these check out, then it's the switch.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
