Old 06-04-2008, 11:03 AM   #2
Samson
Originally Posted by NickCats
Samson,
So, on your road trip, you were able to get around 475 miles between fill ups ? How long can you usually go before you need to fill up normally ?
( Gas tank has a 17 gallon capacity with a 2.5 gallon reserve, so I am guessing most fill up about 15 gallons when they stop )
Nick
I filled up at around 350 miles on each tank, as the other car on the trip needed to fill up more often than I did. I typically had about 1/4 tank or more left, and the car needed around 11 gallons.
I haven't had the car long enough to fill up a "normal" tank, but right now it is sitting just below 1/2 tank w/220 miles. 100 of those were highway; the rest were fun (lots of redline and full-throttle).
I have noticed that the gauge isn't very linear, meaning it will drop from full pretty quickly and hover around half for a while.
http://ericfilcoff.com/pictures/986forum.jpg
2001 Boxster | 2007 Outback Sport
Need a freelance graphic designer?
Samson is offline   Reply With Quote
