Well, check you overflow container. Is it leaking? Pull up the carpet and look there too. If you add just water, it needs to be distilled water. You are OK to add just water if it only needs to be topped-off. If more is required, you need to add a mixture of water and coolant. You need to use the correct coolant too. Do a search for coolant.
