Old 05-27-2008, 05:39 AM   #1
h20break
Originally Posted by hjkim550
Hey h20,
Is this picture after you ripped out a black rubber lining with a mesh attached? As I posted in other threads, mine has a firmly attached rubber lining and mesh that will not come out easily even after the screw is removed.
Did you have to use a lot of force to remove this lining and mesh assembly? I did not do this because I was worried I might damage the set up.
This picture is after the mesh was removed. After removing the top screw mine came out pretty easy. There are two small studs on the bottom of the mesh screen that look like they help keep the bottom of the mesh screen secure and in place.
The snorkle itself took a little work. The easiest way to get it loose was to pull up on on it first. After it loosens just a little you can work it out.
h20break is offline   Reply With Quote
