Old 05-26-2008, 06:47 AM   #17
frederic
No problem with 97 tiptronic...
Originally Posted by Jaxonalden
Yo, yo, J.fro,
Yea, I thought about rerouting the line but if you look at the picture I took, the bottom rubber "T" is right in the way. I don't think it will be possible unless I cut the "T" and install a couple of 90 degree bends that will go between the header and the block (oil sump). ....
Hello.
Just to let you know that I bought the same headers from eBay, and that I didn't have this issue with a 2.5l tiptronic... The 2.5 configuration got 2 cooling line, but one on each side of the oil pan. So if you have a ZF tiptronic transmission, I think that you could buy the cooling lines from a 2.5l and your problem will be gone...
BTW bleeding the cooling system is not that hard, I had to do it because of a broken header stud next to the water pump.
Good luck
frederic is offline   Reply With Quote
