Old 05-24-2008, 08:02 PM   #16
Jaxonalden
Jaxonalden's Avatar
Yo, yo, J.fro,
Yea, I thought about rerouting the line but if you look at the picture I took, the bottom rubber "T" is right in the way. I don't think it will be possible unless I cut the "T" and install a couple of 90 degree bends that will go between the header and the block (oil sump). Not to mention I'm now draining the coolant as well, and if you ever read the procedure on bleeding the coolant after draining...forget about it.
I think I have the tube problem worked out and I'm just waiting for HX Racing to get back in touch with me. I sent my condolences on the earthquake that hit the country, I don't think they were affected.
I'll keep updates as they happen.
