Old 05-24-2008, 12:48 PM   #3
AZDan
I spent a little time troubleshooting this one and it's not a fuse issue. It seems to be an ignition issue.
I discovered, as it started raining, that my wipers are not working either. When I realized they did not work I instinctivley flipped them all the way down (not the off position). When i shut the car off the wiper started as I passed thru the accessory position on the ignition.
So I turned it to accessory and my wipers and blower worked. I started the car and both turned off. I then turned the key slightly to the left, without shutting the car off, and the blower and wipers worked. So it seems like the key is turning to far to the right and cutting of contact for the power.
Anyone have experience with such an issue?
AZDan is offline   Reply With Quote
