Originally Posted by ancster
If you are looking to check the transmission fluid, the boxster uses the same fluid for both the brakes and transmission. You can check the level in the front trunk.
Hold on there, Boxsters use the same fluid for the CLUTCH and brakes, not the transmission. Using brake fluid in the transmission would be a very fast death of the transmission.
Here are the instructions for changing tranny fluid
http://www.renntech.org/forums/index.php?showtopic=7060
The only problem with those instructions is that they say to fill to the fill plug hole. You're actually supposed to fill to 11mm below the fill plug hole.
