Old 05-21-2008, 05:46 PM   #10
Hops
Originally Posted by Jacques79
So you're saying the 987S communicates more road surface changes through vibrations in the steering wheel than the 986S?
I don't think that is true. If anything, I think the 987S communicates less to you. But, as I mentioned in my last post, it is as if the 987S suspension takes care of more for you and doesn't bother to tell you about things you don't need to know. It's kind of like an agent acting on your behalf.
However, as the previous posted noted, the 987S is more responsive to driver input. So, the car is telling you less about the little details of the road, but it is very perceptive to the instructions you are telling it.
A car with higher limits and lower feedback ordinarily is a dangerous combination, especially in a mid-engine design, but the 987S gives you clear messages when things are getting close to the edge, and I have found that it isn't too hard to control near the limit. I've only had PSM kick in once, and it was by choice. I intentionally pushed it past the limit on an on-ramp with lots of room for error.
Hops is offline   Reply With Quote
