Old 05-20-2008, 05:13 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
You will only get alternator whine if the AUX cable is hooked up to a power source. There is no way to completely eliminate it, but you can make it unnoticable at normaly volumes. I used a radio shack ground loop isolator (I found that the ones from Walmart where not as good), and it solved the problem.
