The reason I suggested the Michelin PS2's was cause I run them and they truly at excellent. A slightly less pricey, but still great tire are the Goodyear F1 tires.
The top 3 tires (dry and wet performance) are probably:
- Michelin PS2
- Bridgestone S-03
- Goodyear F1
Bridgestone S-02's are also excellent in the dry.
By the way, also consider the weight of the tires. Many people only worry about the weight of their wheels, but tire weights can differ by several pounds between equal sized tires. For example, a 225 Michelin PS2 is 4-5 pounds lighter than the same sized Bridgestone S-03's (if I remember my #'s correctly). Theoretically speaking, adding/reducing the weight of the tire will have more effect than adding/reducing the same weight to/from a wheel because you're adding the weight to the outside of the spinning wheel/tire circumference.
