Old 05-18-2008, 06:13 PM   #23
heyjae
Originally Posted by Jaxonalden
A heavy dose of penetrating oil, WD-40. Any lightweight oil will do then let it set for a day or two to work into the threads. Then prior to loosening and removing the bolts, fire up the car and allow the bolts to heat up. This is done to severely corroded bolts, mine just took a couple of shot's of WD-40 and the bolts popped right out.
One thing to remember, the heads are aluminum so don't over torque the bolts when tightening.
P.S. Give the O2 sensors a shot also.
I did exactly the same thing and the bolts came off without a problem. In my case though, I did install headers about 4 years / 40,000 miles ago, so there may have been less corrosion.
2000 Boxster S
http://www.slipangle.com/images/ACSpeed_sig.jpg
heyjae is offline   Reply With Quote
