Old 05-16-2008, 06:51 AM   #12
Adam
Originally Posted by Jaxonalden
I read an old post from CJ Boxster and in it he had a IPB (illustrated parts breakdown) of my exhaust system. The picture showed a place for an O2 sensor aft of the secondary cat. If its there and I plug my O2 sensor to that I should be able to operate without getting a CEL, right?
The picture of the exhaust system in post 254 on the Thread called "Performance Exhaust and Header for Boxster".
Yes, I saw that in the diagram. I don't recall seeing 02 bungs before and aft of the secondary cats on my car though. There might be a place to tap and drill a set. 2nd issue with that is your wires for the 02 sensors arent' nearly long enough to stretch back that far so you'll have to cut and splice some extensions. I heard that can backfire because the longer wire has more resistence which can cause a CEL as well. Did you install the headers yet? Let us know how they work out.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
