Originally Posted by eomak
Hi, thanks for replies.The feeling was like i was in 3rd gear starting from a dead start,so i pressed in clucth pedal in again and made sure it was in first.Which it was but this time the clucth pedal didnt seem to be grabing anything.I tried all gears at that very monent but nothing was happening. I was on a hill so manged to roll it onto a side street.I stopped the car and noticed the clucht pedal was half way down like something holding it and pulled it up with my hand and heard it released something but still no enganament of gears.Pedal was tolly freeless to move.I chaecked the brake fuild and its full so i guess its that other part? i hope. Does it cost much to repair? like do they have to drop the engine to get at it?
A Bad Master or Slave cylinder will not necessarily change the fluid level. The problem is that the fluid leaks past the seals, but doesn't leak from the system... still cannot rule that out.
