Old 05-12-2008, 08:22 PM   #3
Jaxonalden
Jaxonalden's Avatar
Dfraccica01,
Sorry to hear your in the sandbox, I see by your login that you're stationed at Spang. I've been in and out of the "fatherland" numerous times flying C-141's. I really miss the beer.
About your leak, "oily" sounds like brake fluid but could also be a leak from an air conditioning condenser (there's oil in the lines to lube the compressor). Brake fluid should be easy to locate but if it's a leak in the A/C system check the lines, fitting or condenser itself.
On my '04 S, I have a big dent on a line that's just aft of the right front wheel. I'm sure it's an A/C line that runs up to the front. Whatever you have leaking it looks like you'll have something to work on when you get back to "The World".
Take care and keep your head down!
