Thanks again ToolP, I took her out for a short drive on Friday and she had no leaks but ran a little warmer than normal. There was no smoke or leaks as I found before I bled her. Am I correct to assume she ran a little warmer than normal is because I used distilled water?
Once I get the hose replaced I am going to flush the coolant and replace with coolant and she should be back to normal. BTW is this the hose that connects to the water pump from your picture below?
