Old 05-09-2008, 10:04 AM   #14
easyc
If you have oil in your coolant, then the engine is most likely dead... have them run a compression and leak down test to just make sure... the most likely culprit is a cracked cylinder sleeve... they may tell you its a head gasket, but I from my experience with the problem, no one I can find has had a head gasket go out on a M96
Lexington, KY Go CATS!
http://i187.photobucket.com/albums/x...s/DSCN0406.jpg
2001 986S... 3.6 swap (yep 7.2->7.8), PSS9's, GT3 seats, OEM 986 Carrera 5-spokes, and much more http://i187.photobucket.com/albums/x...me/burnout.gif
1987 928 S4 white on red and... dead
2004 Chevy Surburban... drinks gas like its cheap or something
easyc is offline   Reply With Quote
