If you have oil in your coolant, then the engine is most likely dead... have them run a compression and leak down test to just make sure... the most likely culprit is a cracked cylinder sleeve... they may tell you its a head gasket, but I from my experience with the problem, no one I can find has had a head gasket go out on a M96
