Originally Posted by ancster
PSM is an option that depends on each person. I wanted it on mine as I wanted the extra safety factor. PASM uses the ceramic brakes and isn't a common option.
I believe PSM became standard in '05.
Not quite correct...
PASM - Porsche Active Suspension Management system. Includes active managment of suspension firmness and a ride height decrease of -10mm from the standard suspension. ( $1,990 )
PCCB - Porsche Ceramic Composite Brake (PCCB) system. Carbon-fiber reinforced ceramic brake discs, internally ventilated and perforated, and yellow painted brake calipers. ( $8,150 )
PSM - Both Boxster models are equipped with Porsche Stability Management (PSM) as standard.
( from Porsche website referring to current models )
Nick
