Old 05-07-2008, 09:43 AM   #10
Tool Pants
Don't forget that when you fill the system with coolant after a water pump replacement you need to bleed the air out of the system. Remove the black plastic plate under the caps and you will see the metal lever for the bleed valve.
Tool Pants is offline   Reply With Quote
