Old 05-04-2008, 01:56 PM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
I can honestly say I do not commonly leave my blinkers on.
But you could probably add a buzzer without too much trouble. Those familiar with the OBC hack will understand what I am talking about. If you figure out which wire going to the instrument cluster is the turn signal all you need to do is wire tap a buzzer on, then ground it to the OBC ground location described on Yoseif's OBC site. Then you could rest the buzzer under the cluster or behind the blank dash switches.
When you turn on your signal, the power going to the dash light will also power the buzzer.
