Old 05-02-2008, 06:50 AM   #2
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
I had the same problem passing NY State inspection after having my battery disconnected. Since the battery disconnection, I drove the car at least 500+ miles, but still couldn't pass because the readiness sensors were not ready. Finally, I read about the drive cycles that you have to perform in order for all the sensors to be in the "ready" state, and off the top of my head, this is what you have to do:
1) Don't drive the car for at least 12 hrs (ie. let the car cool down fully overnight).
2) Turn on the car, and immediately turn on the A/C / climate control system, and run the defrost system at the same time while idleing the car for a full 2 minutes, and then turn off the defrost and a/c.
3) Drive off at medium throttle and reach about 50mph, and then keep it there for a full 3 minutes without touching your brake and clutch pedal at all.
4) Slow down by coasting below 30mph without touching the brakes.
5) Drive off again at moderate throttle to 50mph and keep it there for 5 minutes straight, and then coast below 30 without touching the brake pedal or clutch.
Doing this is very hard in NYC (I had to go up and down the west side highway), but it finally worked, and I passed inspection. The thing is, the way I drove, I always drive with a heavy foot, so I'm always wringing the car at pretty much full throttle in every gear, so even if I drive like this for 500+ miles, the readiness codes for the car would still not be in the ready state. You have to go thru these drive cycles for the car to be "ready" for testing. It stinks, but it works. Oh, and don't ask him to disconnect the battery again.... everytime you do this, he'll have to start from scratch and go thru the drive cycles again, in order for the car to be ready for testing. Good luck to your friend.
