Old 05-02-2008, 05:01 AM   #4
Burg Boxster
Originally Posted by Boxster22
You lost me a little on the hub centric portion. Any more advice on that piece would be good
Jerry-
hubcentric means it has the extended and recessed lips to align the wheel when attached and also the spacer to the hub - much the same as when you put your wheel on now - when on correctly it'll hang on the "ledge" of the hub. Guess a picture would explain better......
2TrunkSteve-
Mine are in the garage waiting to be installed - hopefully I'll get it done next weekend when I paint the rotor "hats" to match. I'll take some before/after shots then.
