Old 03-03-2005, 09:01 AM   #3
Tool Pants
What is wrong with yours.
It is a switch assembly only sold as a unit. The 4 stalk switch assembly cost less than the 3 stalk for some strange reason. I assume you have 3 stalks, signals, wipers, and cruise control. If so and you need to replace your assembly then buy the 4 stalk unit. You can then retrofit the OBC or remove the 4th stalk if you do not want to do so.
Tool Pants is offline   Reply With Quote
