Old 05-01-2008, 09:22 AM   #1
tboyer
tboyer's Avatar
Originally Posted by kurssat
Unfortunately, the remotes do not lock/unlock the car nor do they enable/disable the alarm.
Second question
I have an origional soft top on my car. What should I use to treat the soft top to make it last longer and improve its water resistance?
Welcome to the boards.
Sounds like you have tried all of the typical steps you would to troubleshoot your problem, other than the batteries but I assume since neither fobs work, it's most likely not the batteries. Sounds like you need new keys. I had a '00 that needed new keys too, common issue.
RaggTopp is highly recommended across the board for treating the top.
'06 Cayman 'S' - Sold (Sport Chrono, PASM, TPMS, 19' CAS Wheels, NAV)
'06 Cayenne - Sold
'01 Boxster 'S' - Sold
'00 Boxster - Sold
tboyer is offline   Reply With Quote
