Old 04-30-2008, 11:36 AM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by Lil bastard
Having the Tip S transmission is a reason NOT to go with the 'S'.
This is because in low gear and in second gear, an auto transmission acts as a torque multiplier.
Low gear, the gear used when getting under way, climbing a steep hill, or sometimes when pulling a very heavy load, has a torque multiple of around 3:1.
Second gear has a torque multiple of about 2:1.
In High gear, used at highway speeds, the transmission uses a direct drive gear, meaning that there is no torque multiplier.
And if you have a car equipped with "overdrive," like 5th gear in the Tip S, the torque ratio is in the neighborhood of 0.8:1.
Every auto transmission establishes its multiples with slight differences, depending on what the designers determine to be the most efficient torque multipliers for a given engine in a specific car.
You'll feel less torque in a Base w/ manual transmission than you will with a Tip S.
Good info, Thanks Jim... I mean Lil_bastard.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
