Old 04-29-2008, 09:30 AM   #1
Lil bastard
Lil bastard's Avatar
So far as Calorific, BTU or Joules are concerned, generally speaking, lower octane fuel contains more energy than higher octane fuel.
This is because the additives used to boost octane contain less calories/volume than normal gasoline - they make the fuel more difficult to combust so that it can be better compressed and burn more thoroughly releasing more useful energy. Since these additives displace a % of normal gasoline when mixed for octane purposes, this gallon of octane boosted gas will contain less energy, somewhere on the order of 5-10%. This is also a problem with Ethanol - it contains 30% less energy/volume than regular gasoline.
Now, the issue becomes potential energy.
Some engines, due to better computer control, higher compression, etc. can release more useful energy from octane boosted fuels than normal gasoline, or perform better - create more HP or run more smoothly.
That is not to say they perform badly on regular gasoline, in fact, due to the wide variation in fuel quality around the world, most cars marketed internationally are setup to run just fine on a wide variance in octane. The Boxster is one of these.
Since there is no tetra-ethyl lead in any of these fuels, none of them will hurt the engine or emissions gear.
If mine were a daily driver, I'd use 90 Octane and only go to Super-premium for track or weekend spirited runs.
But, you hardly need to eek out that extra 0.1 sec. 0-60 when commuting.
Now, that said, there is often some variation between what is stated on the pump and the actual octane rating of any particular batch of fuel, in fact, it's usually slightly lower than stated due primarily to the volatility of the octane additives, which evaporate from the fuel as it sits in the Tankers or underground storage tanks. But, if you fill-up at the busiest name brand station you can find, this isn't usually a problem.
Try several grades of fuel, and use the one which gives you the best value for your money. Because of driving style, conditions, source of fuel, etc., there is no one answer to this question - you need to experiment on your own. You won't hurt the car at all. You may run a little rougher, or see reduced range and if so, just switch back. The savings may be small, but in this day of ever-rising fuel costs and uncertain immediate economic future, it pays to save wherever you can.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
