Old 04-28-2008, 05:44 PM   #12
Tool Pants
The bearing in the water pump failed. This causes the pulley for the pump to wobble and the belt is not happy, since that belt also runs the alternator and power steering. That is why you had the warning lights and no power steering.
Here is the pump. Engine is out of the car for this picture, because it is hard to take a picture of the pump with the engine in the car.
The aftermarket pumps have a metal impeller. The factory pump has a plastic impeller. You will note this difference when you replace the pump.
Tool Pants is offline   Reply With Quote
