Old 04-27-2008, 10:01 AM   #1
Lil bastard
Lil bastard's Avatar
Replacing the Waterpump and the belt is a very easy DIY.
You'll need a replacement belt, new or rebuilt waterpump (a rebuilt uses only the existing casting - all other parts, the shaft, bearing, seal and impeller are new), and a gasket. Tool requirements are minimum - 10mm socket, U-joint drive, 19mm socket, E-12 Torx Bit, Pliers.
The PN#s are:
Poly-Rib Belt - 996.102.151.64
Waterpump - 996.106.011.53
Gasket - 996.106.340.51
If you PM me an email addy, I'll send you the procedure as a WORD document.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
