Thread: Ohms-speakers
Old 04-24-2008, 09:53 AM   #3
KevinH1990
KevinH1990's Avatar
Before I can answer your question, I need to know whether you are using an amp to power your speakers. If you are using an amp, you could just drive the speakers from the headunit. If you are already using the headunit to drive the speakers, you will probably need to install an amp and reconfigure things so that you can power 6 channels.
I have the PNP rear speaker kit. Originally, I had the 4 channel HAES (stock) amp that ran the dash and door speakers. That permitted me to run the rear speakers off the head unit.
I later added a 6 channel amp from a 996 and I am now running all the speakers from the amp.
