Old 03-01-2005, 06:04 AM   #10
clubhead
Originally Posted by Lux
Clubhead,
I would attack the problem with:
1. Call Evo.
2. Run dyno and get a/f readings.
Hmmmm... I may just call them to find out. Let's see.
Meanwhile, I've explored putting in a wide band lamdar sensor to read the A/F mixture. But the mechanic here says unless the MAF is way screwed, the A/F will still be in the region of 12-14:1 And if the MAF is way screwed, you don't need the sensor to know things are wrong. You can smell it from the exhaust. Oh well...
clubhead is offline   Reply With Quote
