Old 04-23-2008, 07:46 AM   #19
blue2000s
Porscheectomy
Originally Posted by geoff
My writeup after I installed the 997 short shifter is at http://www.renntech.org/forums/index.php?showtopic=7371&hl= I am still happy with it after 2+ years and have had zero problems.
When I installed the 997 short shifter in my '01 Boxster, I didn't measure the side-to-side difference, just the forward-backward (I measured about 25% front to back reduction). I would expect the side-to-side difference would be about the same, since the pivot point moved to the same point. I don't notice much side-to-side slop.
See http://www.carnewal-europe.com/cpx_p96139.htm for an ad with picture
Just to confuse things, I believe goeff's is the actual 997 short shift kit 997-424-983-00. Which is different from the one that blinkwatt, john v and I have installed 997-424-010-00 . Ours is the standard 997 shifter, which happens to be noticeably shorter than the standard 986 shifter. Geoff's is a shorter throw than the standard 997 but longer than the B&M.
So in order of shift distance, longest to shortest:
Stock 986/996
Stock 987/997
Factory Short Shift Kit 997
Schnell
B&M/factory short shift 996/B&M clone
This is also the order of notchiness, least notchy first. I'm not sure where the swift-shift kit that extends the bottom of the 986/996 shift ball falls. There hasn't been much information shared on it.
