down to the warranty issue
Based on the additional information you supplied, it seems like the CPO status of the '04 is the only real benefit of that car. The '03 has the preferred appearance, options, lower miles, etc.. I can also sense that you are more interested in / excited about the '03.
I'd suggest you get quotes for the best possible aftermarket warranty for the '03, compare the coverage to CPO coverage, and see if that helps with the decision. Also consider that the lower mileage '03 with all service records may be less likely to actually need serious work than the car with more miles and less known pedigree. I always keep in mind that even if service does not cost you $ out-of-pocket, it still takes your time and is usually a big hassle too.
As for the comments about the 18" wheels - I can tell you the car still rides very comfortably with the 18"'s, but the roads here are not too bad (worse than you might think though). So, unless you have real problems with the roads in your area or where you need to drive, I would not be too worried about that. I'm acutally surprised at how comfortable the ride is even with such low-profile tires.
2003 Boxster S - Speed Yellow
