Tire pressure
Yes, I did measure the pressure at the same time with 3 different of guages on cold tires. I've put about 2000 miles on new tires so i don't know much about tread wear or handling at this point as this car is new for me. I use the car for road use only and want to ensure tire performance. I do think I'll adjust the pressure up and down as you suggest to become more aware of how the car handles at different tire pressures. I'll use the guage I think may be the most accurate. I do suspect that it will be driver preference that will indicate relative performance. thanks.
Hookoo3
2001 Boxster S
