Sounds kinda like fuel starvation. In that it craps after 15 minuets (about warmed up) it's no longer running rich and maybe regular lean mode is just to lean. I had this problem exactly in a BMW. Mine was always the fuel filter .
Given you've covered that base, you might take look at the fuel pump. Tests usually involve flow and pressure (2 tests).
Good luck, PK
